yeah i know this has been cover numerous times. ive read them all. but heres the scoop. My tach had been jumping for sometime now. but today i just replaced the external ignition coil. i rev it a little, nothing pass 2500. it seemed like it was fixed until i started reving pass 3000. it started jumping around again. let me clarify that it jumps up but never downwards. it settles back down to its last reading point. alternator and distributor a year old. wtf?
Tach Issues....still.
Do i spy a Check engine light?
02 Crv
Originally posted by agol View Postwhere did you happen to see a check engine light.... btw check engine is always yellow... not red.
02 Crv
Originally posted by jewelproject View Postignition rotor? is that the "ignitor" i never took apart a dizzy so i dont know.
1. Disconnect all dizzy wire connectors(2 plugs n pull the Ign wires from head)
2. Remove the 3 12mm bolts n remove dizzy
3. Unscrew the 3 8mm/Phillips screws holding the cover
4. Rotate dizzy to locate phillips screw holding the rotor n remover both
(may take some force if it's ur first time removing
5. Remove dust cover
6. Ignitor is the smaller device with 4 wires connected disconnect the four wire n unscrew using Phillips.
7. Pat yourself on the back for a job welldone
8. Reverse order for installation
9. Test your skills and fire her up to see if problem persists
10. Smoke a fatty n crack a beer
GOODLUCK n don't forget to thk me for spoon-feeding ya
My car is having the SAME EXACT issue. it jumps as soon as it hits 3000. except mine jumps from 3000 straight to 4200 and stays there until the actual rpms meet up with it again. works fine before 3000 and after 4200. i changed my ignitor today with a brand new one and cleaned the contact points very good. But unfortunately it DID NOT solve my issue. i dont know if maybe we have a bad connection at the back of the cluster or what. i was pissed i just wasted money on a new ignitor that while i was driving the car i hit the dash really hard above the cluster and it started working correctly again. lol but then it start acting up again a few miles down the road
