Help on rpm!??
    Help on rpm!??
    Ok my cb has been given me a problem with the RPM's on my tac it will jump from 1k to about 1.2k but the motor does not feel like the rpm are really changing and at idle it sits at 1k but feels if it really at 700-750 what could be going wrong? Please any help this is really starting to bother me.
    Take a look at my MRT!! Thanks
    http://www.cb7tuner.com/vbb/showthread.php?t=186609
    bad dizzy... or maybe tightin it.
    K20z3
      What sends the signal to the tac. Could it be the mag pick up or the ignitor ? I thought the ignitor send the signal to the tac.
        An erratic tach is very often the result of a failing ignitor. You could also have grounding issues... a bad ground can cause all sorts of fun problems.
          Thanks deev yea I know for sure ground is good. That's what I thought well I'll just pick up an ignitor just to have if this one fails.
            That's a good idea. Even if the ignitor isn't the problem, it's still a part that will fail eventually... so replacing it just prevents that from being a problem in the future! You might want to replace your coil at the same time.
              Lol my coil went out last Friday on my way back home from work.
