I had a couple questions about doing a cam swap. I've been looking for a diy but have had no luck, so if theres a link, that would be great. The quetion I have is, is there a easy way to change out the cam WITHOUT removing the lower timing cover? Skunk2 did a vid of a 5 or 10 minute cam swap in a k24 where the only had to remove the valve cover and I believe the upper timing cover. The used a tack to secure the tensioner and held the belt from moving while removing the cam and then replacing the girddle and everything stayed where its supposed to. I'm assuming the same can be done in a f22 sans the tack in the tensioner, but I don't know. If anyone else has tried it this way, any help would be helpful and appreciated. And I've seen on here a common cam swap is an a6, is there much to be gained going this route? Thanks in advance.
Cam swap
bro the a6 cam isnt worth it. go with a regrind from bisi. the level 2 can be used without changing valve springs. also with two sets of hands you can change it without taking off the lower cover but i do not recommend it. best thing is to go ahead and just change the cam when you do the timing belt.
Originally posted by dj_ender View PostI had a couple questions about doing a cam swap. I've been looking for a diy but have had no luck, so if theres a link, that would be great. The quetion I have is, is there a easy way to change out the cam WITHOUT removing the lower timing cover? Skunk2 did a vid of a 5 or 10 minute cam swap in a k24 where the only had to remove the valve cover and I believe the upper timing cover. The used a tack to secure the tensioner and held the belt from moving while removing the cam and then replacing the girddle and everything stayed where its supposed to. I'm assuming the same can be done in a f22 sans the tack in the tensioner, but I don't know. If anyone else has tried it this way, any help would be helpful and appreciated. And I've seen on here a common cam swap is an a6, is there much to be gained going this route? Thanks in advance.
You can change the cam without removing the lower cover, providing you ensure you don't move the crank while doing the swap.
Have you ever replaced a cambelt before? If you havn't then I'd highly suggest you remove the lower cover so you can see the belt is fitted properly upon re-installation.
My 5.7 LS1 Holden Ute
Originally posted by jdm92_accorn View Postbro the a6 cam isnt worth it. go with a regrind from bisi. the level 2 can be used without changing valve springs. also with two sets of hands you can change it without taking off the lower cover but i do not recommend it. best thing is to go ahead and just change the cam when you do the timing belt.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Unless your timing belt is already brand new, i wouldn't trust an old belt with a performance cam. You may save yourself a few steps short-term, but if the belt slips or breaks, the damage will be far more costly and time consuming to repair!
The K24 uses a timing chain, which is much less likely to snap when reused.
The F22A6 makes 15hp over the F22A1 (in perfect condition.) The A6 gets that power mainly from the cam, intake manifold, exhaust manifold, and ECU... so realistically, 5hp is pretty much all you'd see from the cam, I'd expect (that's just a guess.) Especially since the cam and valvetrain components will already have 20 years of wear on them.
Bisimoto cams are affordable, but they're not cheap. However, Bisi has designed them to work best for the engine, and he understands the F22 better than just about anyone. A cheaper route would be a Delta regrind. They have a decent reputation, though the grinds are pretty generic compared to Bisi's.
Originally posted by evil_demon_01 View PostThe K24 doesn't have an upper an lower cover, Just one sealed cover.
Have you ever replaced a cambelt before? If you havn't then I'd highly suggest you remove the lower cover so you can see the belt is fitted properly upon re-installation.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by deevergote View PostUnless your timing belt is already brand new, i wouldn't trust an old belt with a performance cam. You may save yourself a few steps short-term, but if the belt slips or breaks, the damage will be far more costly and time consuming to repair!
Bisimoto cams are affordable, but they're not cheap. However, Bisi has designed them to work best for the engine, and he understands the F22 better than just about anyone. A cheaper route would be a Delta regrind. They have a decent reputation, though the grinds are pretty generic compared to Bisi's.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by deevergote View PostIt may not be YOUR cam, but yes, it is a reground stock cam. I believe material may be added as needed for the desired profile. I'm not sure on the specifics.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by jdm92_accorn View Posti had the v1 level 2 with bolt-ons and a ported head and made 171whp ,162wtq. idled at 900 and sounded almost stock but deeper. the new level 2's are a better design. it sounded similar to this. this cam is my custom grind idling at 900 but my old cam sounded like this at 750.
actually you can pick up a chipped p06 for $200 or less. you dont have to change the springs, i didnt until i ported my head and drove 2yrs i think before then. as far as the h23 intake manifold i recommend a omni power 68mm throttle body($100 ish), port match the upper plentum to the throttle body, and a bisi heat shielding gasket ($50 ish). i recommend getting it tuned to make the most of that cam.
here is before and after the cam before the head work
Originally posted by jdm92_accorn View Postactually you can pick up a chipped p06 for $200 or less. you dont have to change the springs, i didnt until i ported my head and drove 2yrs i think before then. as far as the h23 intake manifold i recommend a omni power 68mm throttle body($100 ish), port match the upper plentum to the throttle body, and a bisi heat shielding gasket ($50 ish). i recommend getting it tuned to make the most of that cam.
Take a look at my MRT!! Thanks
http://www.cb7tuner.com/vbb/showthread.php?t=186609
here is before and after the cam before the head workOriginally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
I think it was with out ecu cause if it was tune I don't think his a/f would have been that low.Take a look at my MRT!! Thanks
