Headlight Turn Signals
    So, the signal lights in/at the side of the headlights don't seem to turn on. Though, the signal lights on the bumper(where the fogs go) do work, as the signals on the rear. When I turn the hazard lights only the rear and bumper signals light up.
    I've checked the turn signal fuse, its fine. Any ideas on what could be causing this? The state inspection is coming up, I'm pretty sure I need them working in order to pass the test.
    Any help is greatly appreciated.
    Accord 93 LX: H23 intake mani, Ebay short ram, P12 ecu, Full exhaust. Lots of noise... and that's about it, just noise. LOL
    Mazdapeed MX-5 04: Begi Intake, Forge BOV, Ebay FMIC. Whoooooooosh... Phhhff!
    Did you check to see if the bulb was still good?
      Man, you're quick. lol
      I did, they seem fine. Its both turn signals by the way, not just one.
        I would still check both bulbs..... and if you need any help, hit me up....
          Just checked both bulbs, they're fine from the looks of it(meaning that the metal string isn't broken).
            Trust me if it was a bulb the bumper and rear signal light would flash really quick! If you checked under the dash n checked the fuses check the fuses under the hood im sure it might be!
              He said side lights and not bumper lights.
              Does your parking lights in the rear work? When in doubt swap the bulb with a working one. Dont just look at it.
              Retro!
              Hater
                I was saying if its the parking bulbs in the corners the bumper lights would flash/ blink fast!
                Some people have to stop assuming so fast
                  When I use the turn signals, they go at normal speed. I know that usually if the light bulb is busted they blink at twice the speed. Both my rear parkings work fine by the way.
                    That has happened to a friend of mines cb7 lol.
                      Sounds like a ground issue, same type of thing happened to me after I did a wire tuck and left a ground bank unbolted.
