7.5v fuse for turn signals keep burnunig out and gauges go crazy when using signals!
    Recently I changed out the blinkers but kept the wiring the same just swapped out the housing and not even 30 min later my fuse blew out the bulb is fine.The weird part is that when I put my signal to turn left my odo gauge goes haywire and jumps back and forth until I turn the signal light off. I replaced the fuse and it corrected the issue but 15 min later it blew out again the (7.5v fuse)and the same thing happened . Has anyone had this issue? Any help would be greatly appreciated..
    http://www.cb7tuner.com/vbb/showthread.php?t=177927 <MY BUILD PROGReSS
    it won't be because cb7tuner told him to! It'll be because it's time to feed the trouser snake...
    First thing I would do is pull off the signal again and make sure the wires for the signal on that side didn't get pinched and that they aren't grounding out on anything.
      I know the prev owner did a lot of halfassed wiring so I am going to do a wire tuck once I get my new fenders in. Also it didnt start happening until i swapped out my bumper signal lights so I dont know why it would cause it since I didnt change the wiring just the housing. But thats true a wire might be grounding out somewere causing the gauges to jump like crazy only when the signals are switched on. thanks.
        my car had aftermarket taillights and i suffered from the stop/horn fuse light blowing. i fixed it by putting the stock tail lights from the jy on.
          Well technically the ones i just put on are the oem ones and the ones i took off were some cheap plastic ones. so i have the opposite issue. thanks though.
            I found the problem when i was installing my new corner lights the guy that had it before my bro for some reason wired the fog lights with the daytme lights and the fog lights have been cut and it was making contact and shorting out the fuse for the turn signals and dash for some reason i cut and taped the wires up and now I have DAYTIME RUNNING LIGHTS , TURN SIGNALS AND DASH BACK TO NORMAL thanks for all your help and suggestions
