hello i want to buy another f22 motor to start my turbo build.there a place like 30mins from my house that does block work since 1983.i called and talk to the guy he said he can clean and bore the block 1mm over all for $70.i wanted to now if thats a good deal if so how far should i bore the block for my turbo build.i will be using the piston and rods from bisi.and thank yall for yalls help
boring f22a1 motor
Honing it will be necessary, and perhaps a very slight bore so you can run a piston with the proper clearance... Bisimoto will be able to tell you what you need to do, I'm sure (talk to Julio, he's very knowledgeable and helpful.)
But you don't want to bore a significant amount. It would increase displacement, but it would weaken your cylinder walls. The risk wouldn't be worth the gain. If you want to bore, I would resleeve it with stronger sleeves.
are the stock sleeves steal?Accord SE
93se
Members Ride
Originally posted by esskater892 View Postare the stock sleeves steal?
Originally posted by wed3k View Posthonda didnt steal anything when they casted the block.
esskater892 - The F22 stock sleeves are iron sleeves but off course they are a thin iron sleeve pressed into an aluminium block. Aftermarket iron sleeves like the ones we get done for all of our race cars and projects are a much thicker iron sleeves that can support much high combustion pressures with either high hp all-motor or turbo application!
ass. hahaAccord SE
93se
Members Ride
