a6 vs a1 intake manifold
    what is the difference between the two perforance wise or is there a difference... and why do you need the a6 runners to do the h23 intake manifold swap why cant you use a1 runners???
    thanks
    MR : http://www.cb7tuner.com/vbb/showthre...ght=CB7+R3ason
    Originally posted by quaidum
    you being able to see four blocks down the road is resulting in someone not being able to see 5 feet in front of them
    good job, just what the world needs more inconsiderate drivers
    A1 puts out I think 120hp that's with the pt3 ecu and the a6 with pt6 ecu, intake man. and cam give I think 140 hp.
    Take a look at my MRT!! Thanks
    http://www.cb7tuner.com/vbb/showthread.php?t=186609
      the A6 runners have secondary runners that the A1 and A4 do not.
        the h23 intake manifold will not fit on an a1 runner correct???
          F22A1
          F22A6
          See the difference? The H23 manifold is set up like the F22A6, only with a larger plenum and throttle body.
            It's a night and day difference. Highly recommended.
            Life's a garden. Dig it.
              Originally posted by I<3MyHonda View Post
              what's the difference? Night and day. Fantastic $ to hp ratio. Swing by a junkyard and pick one up
              That says absolutely nothing useful.
                Oh ok ic so sweet i have 2 a6 mannis then i need to find an h23 top part then to upgrade it right?
                  Correct.
                    can some rate this mod on how difficult it is??(thats done it before)
                      That's a matter of opinion. Someone that has done it before may say it's extremely easy, but it may be difficult for you.
                      You have to unbolt the manifold... which is a pain because it's pretty tight working back there.
                      Pull the fuel rail and injectors out.
                      You have to remove the manifold and scrape off the old gasket (that's a pain... don't score the metal, or it may not seal properly next time.)
                      Then you install the new manifold.
                        Removing the old gasket is the hardest by far, took me a couple hours.
                        wat?
                          It has to be done carefully and thoroughly. I helped my friend with his, and that part was the most irritating. Not hard, just a pain in the ass.
