speedometer problems
    Ya so my speedometer on my '91 is starting to go out because it will be working fine then out of nowhere it stops working so i was just wondering if i would have to completely buy a new one or what could be the problem with it
    I could be a fuse or the speed sensor. Did u change the cluster?
      CEL for VSS?
      www.PreludePower.com
      BB SQUAD MEMBER #28 V.2
        no i havent messed with it i just didnt want to have to take it all apart and buy a new speedometer and not really have to
          maybe your vss might be bad, if not jst stop by a jy and grab a cluster
          92 cb7 http://www.cb7tuner.com/vbb/showthread.php?t=176886
          91 cb9 wagon
            i honestly dont know what a cluster is
              well i am looking in a repair manual that i bought and it says that it could be the speed sensor but where can i find it because its not displayed
                It's on the back side of the transmission it has two lines going to it
                91 cb9 wagon
                  The VSS (Vehicle Speed Sensor) is REALLY easy to replace. It is held on with two 10mm bolts and has one electrical plug on it. Here is a pic pointing it out. Just get a new one and plug it in where the old one was. I had the exact problem, replaced it and it works fine now
                  Also if you look at the retail prices (AutoZone etc) it is high, get one off ebay for cheap, they all work the same
                    awesome! thanks for the diagram its helpful
