now i know this site has an engine sticky somewhere i saw it longg ago but im using the search function but im guessing i got to get real specific to use it correctly..but anyways as titles says. im not 100% sure but i thinking fitments wouldn't be no problem but would things like harness and ecu come into play?
using lx motor to replace ex motor
Originally posted by JDMSeoul View Postnow i know this site has an engine sticky somewhere i saw it longg ago but im using the search function but im guessing i got to get real specific to use it correctly..but anyways as titles says. im not 100% sure but i thinking fitments wouldn't be no problem but would things like harness and ecu come into play?
F22A1
F22A4
F22A6
try that wording in the searching for a good answer
it really depends on the year ex you have, to the lx you have.
There isnt much of any difference. Put most of the ex parts on the lx then you got a standard ex.
as for the compressor and alternator bracket im not sure. Go to www.hondaautomotiveparts.com to see if they are the same for both years or model cars. If anything, you may just have to replace very little..drop it in and call it a day.
If you are going from a ex to a lx, you dont have to worry about IAB's at all...and if you have an EX with IAB's then all you do is use the manifold and the same ecu. No issues.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
The engines are all damn near identical. It IS an easy install.
If you use the LX motor to replace your EX motor, you'll actually have LESS to hook up... however, you can take parts from your EX motor and put them on the LX motor to gain that lost power (5hp for the 90-91 models, 15hp for the 92-93 models.)
sorry...
reason why is i thought maybe i would have to cut into the harness or something like that and im not experienced with doing things like modifying electrical things..
so the lx engine will drop into the motor mounts? also what does IAB mean? been here for awhile but just never really visited enough to catch onto the slang..sorry again
