ive got a 93 SE an i bought some JDM projector headlights, just wonderin if its gonna be simple plug-n-play or will i have to get a conversion harness of some sort, thanks for the help
oem to jdm headlight swap
It depends what sort of projectors are in there. There are no OEM JDM projector headlights, so what you have is aftermarket... very likely some "ebay" crap, so I hope you didn't pay "JDM" prices for them. The only other option is if someone did a projector retrofit into some OEM JDM headlights (which is what I have on my car).
The type of bulb the projector needs is what will determine what sort of wiring you'll need. Most of them will not take the stock bulb type, so you'll need to either build a conversion harness, or splice new connectors to your stock wiring (I do not recommend doing this... cutting your stock wiring harness is never a good idea!)
If the projectors are intended for HIDs, then you'll need to invest in an HID kit.
