2 weeks ago I put a line from the right rear to the front splitter, inside the car along the floor.Now I just blew another brake line on the other side.On my 91 prelude,I never had to fix a brake line on that car since I have owned it because they put the lines inside the car.Getting a little annoyed with fixing brake lines on this car.
Honda should of put brake lines inside the car
I've had the metal brake lines in the rear seize together and shear before it broke loose and the fuel line rust through right where it bends up to go to the tank on the 4th gen Accord. The brake line I got from the junkyard but every 4th gen in the yard had rust all over the fuel line in the same area so I ended up getting a brand new oem. It's probably the20+ years of salt they get exposed to in the winter in this area.
the oem lines should have anti-rust coating. I live in MN and I've never seen a OEM honda brake line rust through.
I could see if something scrapped it or puntured it but not just rusing all by itself.
Weird..
If you worried about it rusting out again, after you replaced it, spray a bunch of undercoat over the lines.
GL
Brake lines rust from the inside, as well, which weakens them and then at some point they blow at a weak point.
Especially in cars that don't have their brake fluid swapped out every year like you are ideally supposed to. Brake fluid absorbs water from the air, and water accumulates in the fluid over time and it causes the lines to rust from the inside.
If I were you, I'd replace ALL of the hard lines as soon as I could. Then you'll be good.
or just wait for them all to blow one by one, either way.Last edited by batever; 05-20-2011, 02:51 PM.
Its rare but i seen brake lines rust out. But its usually because of a shit load of moisture in the brake system
Its rare as hellWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
