92 accord bumper on 91 honda accord
    I need help on putting on a 1992 honda accord front bumper with the oem jdm foglights on my 91 honda accord i have the bumper mounted on my car right now, but my only problems i have now is trying to get the ends on both sides of the bumper to line up to my side fenders there a gap
    this has been covered lots of times. try the search engine.
    its third from the left...
    SEARCH---control---logout
      If you are going to reply, at least answer the question. Otherwise, when people DO search, they're just going to find a bunch of threads asking the same question, with no answers other than "search!"
      To properly use a 90-91 bumper on a 92-93 model, you'll need the 90-91 grille and headlights. Everything else is the same.
      Though seriously... searching for your answer before asking an incredibly common question is the best thing to do. If people get the impression that you are lazy and want to be spoon-fed all the answers, you'll find very quickly that anyone that knows what they're talking about will ignore you.
      Additionally, using a little punctuation in your post helps people understand what you are saying. If we can't understand what you are asking, we can't answer your question. In fact, I've responded only on your thread title, because I couldn't follow a thing you typed in your post.
        ok i have a 1991 honda accord ex sedan and i want to put a 92 honda accord ex sedan front bumper on my car.. i got everything else to fit but the edges of both side of the bumper to fit i got the driver side to some what fit but theres a gap between the bumper and driver side side fender
          That's still one jumbeled mess of a run-on sentence.
          I misunderstood what you said previously. Just take what I said and reverse it. You want a 92-93 bumper, you need the 92-93 headlights, corner lights, and grille.
            Are the corner lights different also? I bought headlights and the grill from the jy. Could i still use my 9091 corners?
            1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
            Originally posted by keepinitclean
            I give it 2 weeks before you sell it.
              The corner lights are different, as I said above.
                Yea make sure as stated above that you have the front end parts that your bumper is from. I got mix match parts and I have gaps.
                STANCE|WORKS
                  With the matching parts, any gaps that exist are due only to improper adjustment... assuming the car has not sustained damage.
                    They will fit and work but look stupid. 9091 cornerlights are flat accross the front where as 9293 curve outwards more. There will be an obvious gap.
