My Green S light(the one that turns on when you turn sport mode on) blinks on and off every once in a while. What is the cause of this?
What causes the S light to blink in 91 lx?
Its pretty much a " check engine light " but for the transmission
You need to pull the code from it the same way you pull a check engine light
To do this locate the blue male connector above/around the passenger side plastic kick plate
Jump the connector with a paper clip
It will give you long blinks and short blinks
long blinks = 10
short blinks = 1
add them together and tell us the code
good luck
I took a medium large plain silver paper clip out of my right pocket of my pants. Bent it three times so that it resembled a thin silver horse shoe. Plugged it into the blue service connector put the key into the ignition turned it to the 2nd, on not started position, and waited to observe the codes from either the green S light or the orange engine light but I got neither. No codes.
Originally posted by Ice D View PostI took a medium large plain silver paper clip out of my right pocket of my pants. Bent it three times so that it resembled a thin silver horse shoe. Plugged it into the blue service connector put the key into the ignition turned it to the 2nd, on not started position, and waited to observe the codes from either the green S light or the orange engine light but I got neither. No codes.
Im wondering why its not working though, you should at least get a code from the CEL or the S light, i find it hard to belive both units are having trouble.
Originally posted by deevergote View PostIf the S light is flashing, it has nothing to do with the ECU... the CEL wouldn't flash.
If the S light is flashing and there is no code being thrown when the service connector is jumped, then the only thing I can think of is a bad TCU.
Jumping that connector should make both the S light and ECU light give their codes provided they have any
If nothing is happening that makes me think maybe theres a wiring issue with the diagnostic connector?
Where is the TCM? I really need a shop manual for this car. I just haven't had time to get one yet. I was reading about TCMs getting wet or shorting out. Is this common? Do I sound like a kid, asking all these questions? But why? Because. But why ? Because
I have a lot to learn about this car. It's pretty new to me, three days so far.
both ECU and TCU are located underneth the passengers feet, pull back the carpet and you will see a metal plate covering them up. The tcu's generally die from capacitors degrading over time and bursting
And no you don't sound like a kid because you actually type well so i can understand what you're saying without rereading it 4 times.
Asking questions is how you learn. It's definitely encouraged here! As long as your questions are legitimate, and not just due to laziness (we can tell...) then nobody will ever think less of you.
There are two types of beginners on this forum. People who know nothing and want to learn, and people who know nothing and want everyone else to do their thinking for them. As long as you keep yourself in the first group, you will always find knowledgeable people on here that are more than willing to help you.
