Rear defrost not working
    So the rear defrost is not working and I believe it is the button itself. It will not turn on upon depression. I have tried to trace the electrical for it to no avial. Any help would be greatly appreciated.
    Screwing an STD-infested hooker works too... but it's not a great idea.
    Check the cheap and easy fixes first.
    is there anything else not working? like the cigarette lighter? interior light?
    if so, could be a broken fuse... Check there first (all of them) before digging too deep. Fuses are cheap.
    hope that helps.
      it doesnt look to be a fuse. Everything else works fine. I am quite baffled.
        It could just be the button go to the junk yard and pull one off. shouldn't be more than a couple of bucks. But also make sure it's hooked up in the back. Because maybe the light is just blown on the button.
          Its the fuse that says interior light (under hood) btw...
          that fuse connects to:
          seatbelt light
          seatbelt chime
          lights on chime
          keys in car chime
          door lights on door panel
          open door light on cluster
          cigarette lighter
          of course defroster
          and the power antennae
          but it also may just be the light in the button itself. some rear defrosters are slow and maybe you have turned yours on and havent given it enough time.
          if not, trace the wire from the rear defroster to the switch.
          it just seems kinda odd to have a bad button
          Sold to: dbsharp, daheavyking X3
          Bought from:'93CB7Ex, xkjnboix, duffmanivxx, remix405, CB7tuner official shop
            I will do that when I get home. I didnt drive the cb today Left the interior light on and ran the battery dead and didnt have time to jump it.
              Hey could also be the relay in the fuzebox interior panel
              Destiny Struggles To Reassert The Pattern That Was Meant To Be. Also Some Of These Members Are Wise Guys With There Wise Guy Answers . Also only inexperienced drivers put donuts in front . You can follow me but it's going to hurt!
                Does anyone know which relay the defroster is?
                  i DO know the fuse for the defrost is in the interior panel(on my 93 ex). when this fuse blows, your blower wont work either. it says rear defrost/blower motor or something like that on the fuse panel. also do u know its actually not working?because it could just be the bulb out.
                    under the hood fuse box labeled interior light: 15A fuse. Does the cigarette lighter / accessory as well. So if your button and cigarette lighter not working then i would say its the fuse. it doesn't hurt to check either, takes a minute.
