water leakin promblem
    I have 91 accord non vtec just changed the head gasket and all the belts including the timing belt well i go to start it up and when I do smoke starts coming from underneath the header then I get down to look under the car and water is leaking from somewhere above the tyranny and all hoses are good ..could it cone the intake gasket and any ideas about the smoke kinda looks like its coming from were the head meets the block...could the head gasket be causing this all of this
    Sorry to say but either you did a poor job doing the head gasket or your head is cracked/warped. Intake gasket is in the back. unless its your thermostat housing gasket check that
    1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
    Originally posted by keepinitclean
    I give it 2 weeks before you sell it.
      It is coming from the back under the intake on the pass side and I guess I can loosen the head bolts and see if anything is on the gasket it self ....if the gasket is bad on the intake would it leak water...and where could the smoke be coming from I'm pretty sure its off the gasket and the head isn't cracked I had it checked
        does it smoke bad because the smoke could be from you touching the headers and stuff leaving grease and its burning off.
          Check the o-ring that goes into the thermostat housing - The one on the steel pipe that crosses under the intake manifold to the waterpump.
          My 5.7 LS1 Holden Ute
            Like mentioned it could be burning off from the header or trying using a cooling pressure tester to see where the water leak is coming from. Maybe a bad hose thats slightly ripped?
              It's not coming though any hoses Kyle theromsat its coming from the middle of the intake manifold it just drops down right there somewhere so either it could be leaking. Though the head or is there a hose back there that I can't see ..and the header isn't grease on them its coming from under them in the middle of the motor but the header blocks it
                I would say it can possibly be the IM gasket. If its happening behind the IM near cylinder #4, then it is a possibility. You can pressurize the system with a coolant pressure tester to find out...
                www.PreludePower.com
                BB SQUAD MEMBER #28 V.2
