Ok I have 92 ex. Its leaking oil of the right side of the motor. "If looking under the hood". Side with timing belt. Its leaking from the upper part. I think it might be the crank seal?. Already changed vavle cover gasket. Any opinions?
92 ex oil leak need info
Its normal to leak oil from there buy this kit and should fix it. http://cgi.ebay.com/ebaymotors/90-97...#ht_2305wt_939
1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
Originally posted by keepinitcleanI give it 2 weeks before you sell it.
Yea. I ran out money to to get the tentioner pulley so I hope mines still good but I bought every seal gasket. That I could find or heard of. The only thing I don't have is the head gasket but mine should be ok . Rebuilt head. The diy video for timing built procedure doenst work. So I'm winging it. Thanks for the help
Dont do it untill you get the tensioner because if that goes you have to take all that apart again
also i would have a mechanic do it if you dont know about timing and all that. Find someone who will do it as a side job usually charge you like $150
Spin the tensioner by hand to check the bearing and also check for play. I have not had to replace any manual tensioners so far on the 20 plus f22's I've done because it was wearing out (just replaced for piece of mind at owners request). They are pretty durable but for sure good to change if you have the funds and a must change if there is excessive play. A general rule of thumb for me is replace the tensioner every other t-belt change (us Canadians generally change the t-belt every 100,000kms or 62,500miles) and you'll be fine.
As for the t-belt, download the service manual and read it before you start. When you go to work on it, double check every thing you've done after. ESPECIALLY the position of the cam gear and lower crank cog for the timing belt and the 3 cogs for the balanceshaft belt. It's very easy to be off a tooth on one of the gears if you aren't careful.
Also, set the engine to TDC before you start and mark the rear balanceshaft cog and lock it as per how the manual says. There is a dot on the gear but it is NOT for 12 o'clock. That dot is supposed to line up with a line that is on the housing at roughly 4 o'clock.
If you are unsure of all this as it is a big job for a first timer, I'd leave it to a shop or a good backyard mechanic as you have a lot to lose if you screw up. Even with the seals, if you don't install it properly and nick the new seal, the leak will be worse than the old seal.Last edited by YK86; 04-25-2011, 06:28 PM.
150 that be nice. Here in ohio it won't be that cheap even as a side job. But ill at least get everything off then try to order the pully. Thanks guys for your help. And yk86 thanks for ur detailed information. I will try this myself. As I have been screwed by every shop I go to. Probably because I'm young. But will love to know how to do everything myself.
