strange leak.
    strange leak.
    pop my hood to look at my fuses and see this spraying, what looks like water all over the place. i have no idea what that line goes to, but i think it was water coming out since i don't have any coolant. didn't smell like gas or oil. plus it was clear liquid. so im sure it was water.
    so i was thinking once it cools down i'd just electrical tape it up.
    pretty sure thats the vehicle spped sensor. someone correct me if im wrong?
    Originally posted by scudweiser
    i farted while i was getting head once, i was drunk.
      it's that rubber tubing there, that i circled. i think the speed sensor is the green thing in the pic?
        It's coolant.
        Yes my name is Dang, Don't use in vain
        1992 Honda Accord EX (Coupe/Bordeaux/Auto)
        1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
        2008 Honda Accord EXL (Coupe/SanMarino/6spd)
          Why are you going g to rig it with tape! What is the point? Its leaking from the hose so why not replace the clamp?
          Its not rocket science. Fix the stupid clamp.
          Retro!
          Hater
            its not the clamp its a hole in the line
              If the pressure went thru the rubber line, it'll most likely breeze right thru any kind of tape.
              Get another line after you identify the hose, which I think is also water, seeing that you stated
              you're not running coolant .. why, I have no idea .. but .. in Florida?
              My CB9/Wagon Thread Start to Finish:
              http://www.cb7tuner.com/vbb/showthre...ighlight=wagon
                Where i circled.
                  im a poor cracker.
                    im a poor cracker.
                    Chriss, this is the heart of your CB7 we're tawkin about here son!
                    Then again, I've never heard of anything breaking with plain ole water ..
                    Nevertheless .. replace that hose .. like yesterday!
                    EDIT: Would that not be the heater hose?
                    I burst a leak in mine once .. nnnnot good.
                      yes sir, ill stop by jy in the morning see if i cant get one. it stoped squirting after i twisted it, but not saying it wont leak again.
                      i woulda never noticed it if i hadn't pop the hood to check the fuses, luckily it looked like it just start to spray and hasn't been leaking for long when i found it.
                        Oh, it will leak again .. and you're very lucky, mine took a shit while I was on the freeway.
                        Lost most my coolant when it went BOOM! Coslty lil tow over to Kyles place .. thank you very much.
                        BTW, that lil rubber hose (if it is in fact is the heater hose) is only like 4 bucks!
                        Prolly one of the least looked at and or replaced hoses by any of us.
                        Which could cause a heap of trouble if not maintained .. imagine that ..
                          lol give me your car since you dont care about it
                          COUPE K24
                            wow...really man spend 5 bucks on a hose and 2 new clamps and no more problems..
                            fill your coolant and bleed it out properly...
                            this is depressing
                              that cost 80 dollars sir
