Exhaust for stock motor
    Whats up fellas? I have a 91 with 160k miles on it. I already have a cold air intake, but looking for a little more outta the stock motor til I can afford a swap. I have to swap out the cat anyways, it's rattling. So, do I use a stock cat? What header would be best, doesn't have to be top of the line. Any and all help is appreciated. Thanks.
    Contact me for custom vinyl stickers: StickyFingasCustoms@yahoo.com
    I would go with a stock oem cat you wont notice that much of a diffrence with a high flow cat and get a DC header its carb legal
    MRT: http://www.cb7tuner.com/vbb/showthread.php?t=196248
      What about mufflers? What would u suggest?
        part 1 ) when i started with exhaust , i would buy parts and not install them until i had it complete. for a few bucks you can score a F22A6 exhaust manifold , then replace pipes with 2.25 plumbing, the factory catt. will be fine . for low budget hp. increase . ( not much , but it will add up )
        part 2) if i had it to do over i would get a apex ws2 muffler . i have a magnaflow and i do like it , but its kinda loud . a great j/k find is a 06- civic stock muffler or any wrx muffler .
          thanks for the help, ill see what i can find. So the F22A6 exhaust manifold will bolt right up and flow better? Ill hit up the junk yard again then, or ebay, or CL. thanks again
            If you have an F22A4, the header on there is pretty good.
            In CA, you'll need a CARB exempt header, so DC Sports is one of your only options. OBX might be... worth looking into, anyway. They're cheaper.
            You won't gain much from a header, unless you get a Bisimoto header.
              Maybe I'll just keep the stock one on there.
                There is a member local to me who ran a high 14 with a stock axle back and bolt ons with an f22. You dont need an aftermarket exhaust to get performance.
                  I'm not expecting too much on the performance end of things, just a little better sound. Not gonna worry about performance til after the swap...whenever that happens.
                    OEM cat is gonna cost you. If the old one is just rattling, it may just be the heat shields. I was gonna replace the cat on my EX because I had to cut the studs to remove it from the flex pipe (flex section rotted)and both heat shields were gone. Aftermarket one I bought was a POS. I salvaged the OEM by installing new studs. Probably shouldn't have bothered, but I put new heat shields on as well - looked great (should have taken pictures!).
                      I find that hard to believe... unless that member absolutely stripped the shit out of that car. Drop the weight to 1800lbs like kentucky_accord did, and sure... it'd run quick with a near-stock engine... but I haven't even gotten into the 14s with my H22 yet!
                      Yeah, a true OEM cat is not cheap. I have an aftermarket cat on my car that a muffler shop installed... the cat and the full custom exhaust (muffler too) was $400 installed.
                      Most "performance" cats are crap. Especially when they cost less than stock. SMSP makes a decent performance cat, and they're actually pretty reasonably priced. They just need flanges welded on.
