A6 head on a A1
    A6 head on a A1
    Ok so im plaining on changing my head gasket sometime soon and I was wondering if the a6 head will go on my car with out any problems. Im getting IM with it to. My reason for doing this is because one of the bolts in my rocker arm assembly didn't go down right so it stripped so it free spins and it was the one for the VC bolt for the front so it wont get tight because it just turns so oil leaks. And thats my reason for changing whole head because of that and just might as well upgrade it to.
    Just to state I can fix the striped bolt but I figured if I can put that head on and not worry about that and gain a little power at the same time.
    STANCE|WORKS
    The F22A head castings are pretty much identical, if not 100% identical. The only real difference is the camshaft and valvesprings. It will go on with absolutely no problems, as long as you install it correctly.
      Ok I just was checking thought same thing didn't want to go waste my time on something that wasn't going to work.
      STANCE|WORKS
        Would'nt you have to get the A6 Ecu as well?
          For everything to run properly? Yes. It will run on the PT3, but not as it should. The PT6 has the proper fuel map for the camshaft, as well as the programming to operate the IAB system in the intake manifold.
            im deffinetly doing this some time this week. will the in take mani on f22a1 work on a6?
              The heads are identical, yes. How many times does it need to be said?
