VTEC sound on non-VTEC motor
    so as im driving and i put my foot into it. is it normal for our cars to feel like vtec at 4k. i dont have vtec but ill be driving it and even putting my foot half into it once it kits 4k its like theres a small vtec feeling. is this normal or not?
    Accord SE
    93se
    Members Ride
    Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
    Sold to: sulimed, BurtonRiderT6, tishock
    If you have an a6, it's probably the IABs.
      The IABs open around then. If you have an A6 (which is the stock motor for all SE models), that is what you are experiencing.
      You could also have your ignition timing advanced, which would put the powerband in a higher RPM range than it should be.
        powerband? when the car begins to make the most power
        Being normal is probably the lamest thing you can try to be
          The powerband is the engine's most usable range of power production.
            reply
            wow solid! im lucky i found me my f22a6..
              What the hell is that supposed to mean?
                at around 4k, i usually just step on the pedal harder to give the same effect.
                  I haven't driven my car in forever... so VTEC kicks in whenever I stop humming "mmmmmmm" and start yelling "BAAAAAAAAAAHHHHHH" while sitting in the driver's seat.
                    wut exactly are IABs and wut does it do......sorta new to this...also i have an a6
                      Intake air bypass, the "secondary intake runners".
                      It keeps the 4 valves in the intake manifold sealed shut. When those valves are closed, only the primary runners are flowing. Once you are in the high revs, the box releases the vaccum and the spring loaded valves open up so that you have secondary intake runners, which allow you to flow a higher volume of air at high RPM.
                      ... or something like that.
                        yes i remember this same vtec sound from my couzins EX a6 but i believe he had ported and polished the head and intake manifold. I must say i love the sound when he steps on it
                          thanks for the info on IABs.. i was curious what they were since i'm always hearing ppl talk about a similar function to vtec.
                          so the f22a6 motors are the only f series with the IAB function? and the h22 motors have it as well am i right?
                          RIP '91 LX.
                            H22 and H23 motors have it, and I'm sure the later model F series have it as well. The F22A6 is the only engine among the 3 USDM CB motors that has it.
                            It's not really similar to VTEC, other than the fact that it flows a greater volume of air at a higher RPM. VTEC adjusts the actual cam profile, and has a much greater impact. The IAB system is nice, though.
                              IAB's are great and that's what your feeling, it's just more air I believe that goes more directly into the combustion chamber. I believe that's it.
                              Current:
                              2007 Acura TL Type-S 6MT KBP
                              Past:
                              1992 Honda Accord EX-R Sedan - RIP
                              1991 Honda Accord EX-R Wagon - RIP 10/14/2010
                              Words change lives. You just got to choose the right ones.
                              Instagram: @CB7Nub
                              Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
