Brake Rotors Wont Come Off!!!!
    Ive been screwing around with these things for a bout an hour and a half. cant get my brake rotors off my 93 lx. i know that the whole bearing comes out with them, i just cant get it to come loose. any tips??
    Originally posted by scudweiser
    i farted while i was getting head once, i was drunk.
    Do you have access to air tools?
    http://www.youtube.com/watch?v=5xIUAMl-oRQ
    92ex CB7<-SOLD 93ex CB9shiftingshift73C10
      Awesome, yea i have an impact gun and what not. thank you!
        just an add up question guys.. coz i was gnna change my rotors but I fail because to take off rotors u gotta ubolt the big bolt in the middle right and then the 2screws to slide it out.. but my rotors have 4hex bolts and I couldnt take it off.. its crazy but can anuone help me please?? my rotors are messed.......
          The removal of the front rotors is pretty involved. You need to consult a manual for the procedure.
            You will need the large Axle Nut Socket to remove that large axle nut with an impact gun!
            The 4 Hex bolts will remove the rotor from the bearing. This will be done after you have the knuckle out of the car. Make sure you use a 12 point socket for 12 point bolts and a hex socket for the hex bolts!
            To have loved and lost is better than to have never loved at all #CB7Life
              Sometimes
              sometimes its good to take a torch to it
              Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
              93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
                even better to take it to a pro
                  Exactly.
                  Look at the link above, and look for threads in the DIY section (there are at least 2 that I know of.) You CAN do it yourself... I have (well, I've helped my friend do it), but there's much more to it than simply undoing a couple bolts and screws, and sliding the rotor off.
                  If you do it yourself, be prepared to replace your ball joints if you tear a boot. Check for torn boots now, and if any are, replace those at the same time as the rotors.
                  To make the job easier in the future, you can convert to "rotor over hub", which would make the rotors as you expected... a couple screws and it comes off. TASauto.com has a kit, or you can assemble parts from other Hondas with that setup.
                    remove the spindle and take the 4 14mm bolts loose on the back by the bearing and the 14mm bolts on the front and bam, rotor is off. simple as that. takes a little time is all. slide hammers and beating the bearing apart are completely unessesary. 90% of time you will damage the bearing doing it that way. good luck.
                    ODBWeldingWerks
                    Team Kindred Impulse Jax FL
                      i forgot about those 12 point bolts.
                      ODBWeldingWerks
