so installed my MSD Ignition yesterday, everything works fine and installed it with the help of the DIY. Anyways, my questions is... how better is the coil that MSD or ACCEL makes versus the stock HONDA? and... I read somewhere that i can make a slightly bigger gap in my spark plugs since i have stronger pulses, does anyone know what the gap should be or is this even true? thanks in advance
MSD Ignition Questions
i put on the MSD ignition cuz i got it for cheap on Craigslist! i got it for $20 bucks and shot right for it. after i installed the MSD i did feel a faster pull, of course it doesnt give you more HP but i honestly felt it get to higher RPMs faster,it kinda felt lighter too. iono maybe just my feeling... any idea how i can figure the gap increase? Does the gap give u more power? or why would it be beneficial?
Originally posted by 415Riderz View Posti put on the MSD ignition cuz i got it for cheap on Craigslist! i got it for $20 bucks and shot right for it. after i installed the MSD i did feel a faster pull, of course it doesnt give you more HP but i honestly felt it get to higher RPMs faster,it kinda felt lighter too. iono maybe just my feeling... any idea how i can figure the gap increase? Does the gap give u more power? or why would it be beneficial?
Having a larger gap and still igniting the combustion can make a little bit more power. The theory behind it is since the gap is bigger and as long as it is sparking and not blowing out, you will have a larger spark and more efficient.
I haven't messed with MSD stuff, but on my M&W setup, I still run a small gap, but thats with a decent amount of boost.
How fast the RPM climb has nothing to do with the spark... and you'd need to make significantly more power for that to be noticeable otherwise. The only other way you can change the rate at which the RPM climb would be to change your transmission gearing.
You also made nothing lighter... in fact, you most likely added a tiny bit of weight!
The plug gap won't make a significant difference. If what D1sclaimer says is true, you will get MAYBE 1-2hp out of it. Probably at the cost of fuel economy.
