Hello there guys, dont usually post on the forums, as whenever I have a problem, I go through past threads and usually find my solution. Anyways, I have a werid problem that i havent found the solution for.. So before I bring it to the shop, I just wanna get some input before I go!
Whenever I step on the gas pedal for acceleration, it goes up a certain amount of time then loses power? Im not quite sure how to say it. I would have to release the gas pedal and then accelerate it once again to pick up power, but then it'll just lose 'power' once again. If I were to drive for a bit longer, the Check Engine light goes on, and the problem disappears. Im thinking this might cause my Check Engine problem. Also, my car makes this.. werid loud rotation noise as it picks up a certain amount of speed. It sounds like.. the pipes are turning, and it rotates faster as I go faster.
If I didnt describe my situation well enough, Ill take a video of the problem! If you guys have any more questions, I will defiantly answer them.
Help me out please and thanks in advance guys!
