camber question
    camber question
    i found a camber kit for the back of my car so i can set negative camber so that i can tuck my wheels in
    but what i cant find is a camber kit for the front that allows for negative camber
    most camber kits that ive found only allow for positive camber
    and the only camber kits i find are the bolt type, but im looking for the camber arm type
    does anyone know if they actually make front upper camber arms for our cars?
    90 accord lx
    form > function
    Member's Ride Thread
    are these what you are talking about?
    http://www.tasauto.com/Product/Detai...805&d=1541&p=1
    I have zero experience in this area.
    92ex CB7<-SOLD 93ex CB9shiftingshift73C10
      what brand of camber kit did you find that will let you do negative adjustments? most camber kits correct the negativity.
      "My FOR SALE thread - Click here"
      MEMBERS RIDE
      99 SILVERADO
      WHEEL FLIP
        the rear upper control arm from wicked tuning
        i found on ebay
        it allows for -3.00 degrees to +4.50 degrees of camber in the back
        but i need some for the front
        90 accord lx
        form > function
          There is no "camber arm type"
          The anchor bolt type and the ball joint type do exactly the same thing, just by moving different parts.
          Honestly, the way the front is, there's not much more you can do to get more negative camber other than just lowering the car further. Anything that would slide the arm back more would make contact with metal.
          You could always have a custom shortened control arm made. I believe people have used an adjustable upper control arm for an EF Civic. I wouldn't recommend mixing parts like that, but it may be worth looking into if that's what you want to do.
            Where did you get the info that ef civic camber kit control arms work
              i cant really go any lower, and im kind of stuck with the wheels that i bought with 0 offset so i wanted to add a lot of negative camber to get them inside the fender and i was also going to roll my fenders.
              i might look into the civic control arms but i might just have to find another way to make it work.
              thanks for the info
              90 accord lx
              form > function
                spc balljoint camber kits can either do +3 degrees positive or negitive camber.
                Deev hates balljoint kits blah blah blah LOL (ducks head and runs for cover)
                Retro!
                Hater
                  A few members here have used them. I believe excalibur02 has them on one of his cars.
                  It's not something i would trust, personally.
                  Because the stock control arms are not intended to have the ball joint pressed out... it is unsafe to put that thin band of metal holding the joint in place under such stress, and then add an adjustable piece that will add even MORE stress on such a vital suspension component!
                  Installed on a new control arm that does not have a ball joint in place already (which means aftermarket...), the ball joint kits are fine. I happen to have one on my car.
                  I don't "hate" them... I just like to educate people about the risks they're taking before they kill themselves, or break their cars. Maybe I should just start giving out shitty ricer advice like everyone else. Then I won't be criticized for actually thinking...
                    I like getting you fired up. LOL.
                    Retro!
                    Hater
                      Bastard.
