Engine stutters between the approximate RPM range 2400-3600. Most noticeable on acceleration, but also occurs with a constant speed. Engine runs more roughly that it used to, and runs slightly hotter than it used to, and seems to lack the amount of power it used to as well. Problem also becomes increasing noticeable as the engine warms up, from hardly noticeable at all when the car is cold, to very noticeable when the car is hot. help
loss of power
Have you replaced the anything to do with the ignition or fuel systems? If they are still stock or have been replaced awhile ago or replaced with cheap parts one of them could have gone bad.
I would start at your plugs work you way through testing all the ignition components (plugs, wires, cap ,rotor, coil, ignition control, igniter) then check your O2 sensor (they go bad and alot of the time dont through a CEL when they do.) after that check your injectors make sure they are working right.
This can not be correctly tested with out a multi meter So I hope you have one or can borrow one.
I get a similar loss of power with my car, and I believe that it is the fault of the o2 sensor (the issue went away when I switched to a fuel map that disabled the o2 sensor)
If your CEL comes on at highway speed, around 50mph, then chances are good that it will read Code 43... which is 99% of the time pointing to the o2 sensor (even though it says "fuel supply system")
If you have oil inside your distributor then yeah...fix that first.
If it's the cap gasket or the o-ring you are in luck. If it's the inner seal/shaft seal then you may want to consider just buying a new distributor.
I was thinking it was the rotor button set screw...as we all know they like to back themselves out.
I would replace the spark plugs too if they are old/worn. At roughly $2 a pop it's worth it.
o.k just replaced the rotor and cap. its still sputtering, but i do feel more power. I believe replacing it was way over due. I still could not find the set screw, so i just simply pop of the rotor. there wasn't any screw on the shaft holding the button on, must not be JDM.
I was talking to a friend of mine and he suggested the MAP sensor. think that would have a affected on it.
