losing clutch pressure
    i blead my clutch twice still losing pressure. im thinking its just the slave cylinder itself. are the f22 and h22 slave cylinder's compatable?
    you might as well as replace the CMC also since you're already bleeding the system now.
      now im thinking its the release bearing, so im just gonna go with my cb tranny and see what that does.
        The bearing would not cause a change in pressure, nor would changing transmissions fix the problem. The ONLY thing associated with clutch pedal pressure is the hydraulic system... unless you snapped or bent a bunch of fingers on your pressure plate. Even then, I don't know that you'd feel the effects at the pedal.
          Master Cylinder? This happened to my Firebird (I know it's not the same car), but I always thought it was the Slave Cylinder. But after all, it was the Master.
          98' Mustang 3V Swap
          11' VW CC R36
            It could be either. It's one big hydraulic system. They're old wear items... so BOTH should realistically be replaced at the same time. Bleeding the system can be a pain in the ass... I currently can't get full pressure in mine yet.
              the reason im thinking it the release bearing now is that it seems to be getting stuck in gear sometimes and im hearing a chatter sound from the clutch
                its the master cylinder, change it and be done
                  well it was the release bearing, changed it and put the f22 trans on the h22 and loved it.
