over heating w/ head gasket done less thank a year ago
    So today i ran my cb for a 5 mile drive and it was over heating like crazy at least thats what the gauge was saying but i saw no smoke anywhere..also i just go all the gaskets replaced including the head gasket,new radiator ,thermostat, timing belt but unfortunately no water pump replacement was done( <i know so dumb ) also iv'e noticed a small amount of oil leakage so when i looked under the car when it was raised i saw oil all over starting from the head down ...i also think my valve cover is soaking up some oil too since i looks shiny more or more like a wet look ... so these are my conclusions..
    1. bad head gasket or improper installation( also because I'm unsure if the head bolts were replaced or reused even though the mechanic said he got new ones with the new head )
    2. Bad Temperature sensor ( was not replaced when other major engine work was done )
    3. Bad water pump
    so tell me what you think i maybe ..remember it's not smoking.. i remember i had smoke when the head warped on me so i don't think it's that even though it's kinda leaking small amounts of oil
    Last edited by ambientwater; 03-25-2011, 03:44 PM. Reason: for got to cross my t's
    Calling your USDM Accord "JDM" is like calling President Obama "African".
    Well the oil might be a warped head this happened to me after i overheated. I think you have a bad thermostat mine lasted 5 months.
    Originally posted by Gummiegorilla
    Damn CBs are like a Rubix Cube sometimes !!!!
      the beginning of your post i didn't understand but as i mentioned i just got my head replaced because it was warped before
        so first thing, you cant assume the head gasket yet. You said its oily on the valve cover so it COULD of trickled down. So clean your motor.
        Second, when it overheats open the engine bay and CHECK AND FEEL the lower and upper hose. If the top one is hotter than the bottom then you have a thermostat issue.
        I believe you can check water pump impeller flow by taking off the top hose and seeing if you got flow on start up. I think you can see it to with the radiator cap off but not as evident if the radiator is full.
        You can also have air.
        Retro!
        Hater
          http://www.youtube.com/watch?v=ua2wu7kojgA
          Watch it it shows how crazy its acting its my dd so it was fine yesterday over heats quick
            Fixed !!!! i was he damn heater hose ...didn't see it leaking until i put the heat on full blast...thanks for the input guys
              Good job dude!
              Retro!
              Hater
