Is there a way to clean an oxygen sensor, i dont wanna buy new ones cause i'm planning on getting a "new" engine in a month or two. Thx in advance.
Oxygen Sensor
even with the "new" engine youre gona need a new o2 sensor..
and no an o2 sensor cannot be cleaned without damaging it
Rush
Originally posted by DarkcloudBought 3 things, 1 that goes boom,1 that shades and 1 to go fasrer
Originally posted by bmxicansdso you got a boombox, sunglasses and rosettta stone?
Until he clogs his catalytic converter and has to replace that as well... and they're not $32.
As cb7rush said, you'll need an o2 sensor for the new engine... so get it now. Just be sure to get one that will be compatible with the new engine, as splicing o2 sensor wires doesn't always yield the best results (it can alter the resistance, causing inaccurate readings.)
Originally posted by all_accord View PostThey are like $10 at your local pull-a-part sure there's a chance it won't work but you can take it back and get another one
I saw the diagram with the o-ring before putting the O2 sensor on that must be changed. When you get the new one, does it come with that already? Or is that a washer and it's included with a new one?
Thanks.
if you really want to "clean" the o2 sensor try this.
1: remove the sensor. dont just remove the sensor. heat up around the thread area with a torch. if you dont have a torch then drive around for 20 minutes or so. get the exhaust noce and hot. shut off car and immediately go to sensor with socket and remove.
2: take sensor and spray area below threads (thats inside exhaust pipe) with carb cleaner. soak it wet with the stuff. now take the torch and apply flame to area that you just sprayed. will drip flames and posibly flare up. keep the flame on it til there is no more residue on the sensor area.
3: now spray same area as before with brake cleaner. apply flame again. again watch out for dripping flames and flare ups.
4: repeat step 2
5: repeat step 3
6: apply flame again until sensor area is red. allow to cool by air or just blow out with compressed air from air gun
7: apply anti-sieze compound to thread area on sensor and reinstall into exhaust. connect wire and drive happily until you can get a new sensorKyle C
2002 Accord Sedan EX - standard- daily status
1991 Accord Wagon LX - auto - 304K & slipping transmission
