Question for those that have GC coilover sleeves. Do the taller threaded sleeves go up front or back? I bought them used, and they are already on struts. They just look wrong lol.
Ground Control question
If they are off a Prelude, they aren't right for your car. Period.
The taller ones go in front, because thy are holding more weight. The short ones go in the rear. If they were already on shocks, this should have been obvious to you. The ones on the rear shocks went in the rear.
See... short springs and taller lower mount go on the rear shock. (middle picture)
I know they weren't right being that they where on a prelude, but I've had integra coilovers on a civic because they where stiffer and worked well for autocross. So I was thinking it was the same concept using a prelude set up. Plus koni yellows, and GC for $ 80. The pic you provided is not how mine where mounted. Looking at my Tein springs is what made me think the set up was put together wrong. I didn't mount them incorrectly, the guy before me did. I'm not a total rookie lol.
Mount them as the picture shows, and they should work.
However, Prelude shocks shouldn't fit on your car... at least either the front or rear sholdn't even bolt up! I do agree that $80 is a good price, though. Personally, I'd sell those for a profit, and get the proper parts. Ground Control will give you pretty much any spring rate you want when you order. They don't have a "one rate fits all" application.
The front struts do work. The rear ones do not. I called GC a couple of hours ago, and the guy said the spring rate will work fine. I got everything straightened out with what springs go where. So ill get some rear konis and go from there. I though of selling them, but after that call I figured ill go for it. I can't believe the other guy drove on them like that. Rear set up was mounted up front. Oh well, some peoples kids lol
Suspension is the one thing that I always tell people... "if you can't afford to do it properly, you can't afford to do it... period!"
You're not halfassing it like most people on a budget do... but you're learning that taking the cheap way out might prove to be more frustrating than just saving up and buying the right stuff brand new!
The site that I got that picture from was advertising the GC/Koni combo for like $850.
