Compression in cylinders question
    So I had my car towed to a shop because it keeps dying on me and won't turn back on. Did most of the usual stuff to try and get it up and running.
    Anyways. The shop was saying that it could be the timing belt or compression in the cylinders or something.
    My question is has anyone ever had to have a shop do this and how much it cost. Is it even worth it to pay an insane amount of money for this or should I just get an new motor or car. My car has over 220,000 miles on it.
    '93 Black LX {DD/Project}
    usually labor is about $60-75 a hour.
      What is "the usual stuff" ?
      Sounds like an idle issue to me though. When does the car die? We need more details if we are to help you.
      '94 JDM H22A: 178whp 146wtq
      If you say double dutch rudder, i'm banning you...
        Spark plugs, wires, distributor cap, rotor, fuel filter, fuel pump, ignition coil. The things that everyone says to check first. The car wouldn't start before the ignition coil was put in. Then two days later it won't start again. When it did start it would sputter like crazy all the time. When I was stopped and when it was driving.
