Just wondering if all you have to remove is the exhaust pipe to change oil pan gasket? Mine is leaking bad.
oil pan gasket?
You have to remove the crossmember that runs under the pan as well. Make sure when you remove the old gasket that all the metal spacers come off the block (I had my first pan done by a dealer, left one of the spacers there, the new gasket leaked like crazy). You may also have to remove the cover from the bottom of the transmission housing to get to the bolts on that end of the pan.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
