idle drops after vtec
    when i punch it and then come to a slow down the idle drops and then car wants to shut off. wtf i have to click the key off and on to go back to normal. as long as i dont past 5000 rpms im good.
    Click here to see why my signature was deleted.
    i take it i'm just basically screwed with this problem. something is gotta give.
      What engine are you running? (because an F22A doesn't have VTEC... we have no idea what you have unless you tell us what was swapped in...)
      What ECU are you running?
      Is your check engine light on?
      Is your ignition timing set correctly? Is your valve timing correct?
      Do you have a vacuum leak?
      You're giving us absolutely NO useful information with which to help you... therefore, you have gotten no help. Give us some more details, and maybe we can help you. Otherwise, yes... you're on your own.
        Vtec
        COULD IT BE YOUR VTEC SOLENOID ...Mabe its not switching back to the lowest cam profile like it should.That would make it harder for it to idle.(mabe because of lack of oil pressure)
        I would change your OIL FILTER and mabe clean the vtec solenoid
        Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
        93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
