HI! I'm Sergio from Spain.
Put some photos to share the proyect!
Hope you like...
The idea was to create a street turbocharger system capable of make good numbers but pulling always from the bottom. Is not a drag car. Fully AC compatible and CARB approved with new homologation card.
The car:
- Rota 17" bronze
- Toyo R888 225/45/17
- Skunk2 struts with MSR spring (6kg - 4kg)
- EBC brakes
- EBC redstuff pads
The engine , F20Z2 is the european non-vtec Sohc F20 - 138HP
The parts:
- Stock engine
- Skunk2 Cam gear
- DSM TD05H-16G from EVO5 internal gated 8psi
- Header MSR
- Dowpipe MSR 2.5"
- Intercooler MSR pipes 2.25"
- Complete exhaust system MSR with sport CAT (200cells) 2.5"
- IC pipping MSR from 1.75" to 2.5"
- BOV Forge Subaru STI model
- DSM 450cc
- Oil cath tank MSR
- Oil cooler CXRacing
- Arospeed fuel regulator OEM rail.
- Front engine mount conversion MSR
- Dual slim fan
-Ac autotechnics oil press and temp
- Greddy E01
Crome Pro tuned from JK
Photo:
The poor F22 stock after 80000 milles
The fab
Header
Downpipe
Pipping
After some turbo work we see on Dyno that making this variable pipping exit the torque line is sharp and controllable when kicks the turbo.
The finish treatment
OIl
Injectors, cath, fuel regulator...etc. etc...
Finish
The first pull... only 70% TPS cause we have a fuel problem with the battery voltaje and the car falls lean if the 100% tps and 8 psi line is used.
5th gear from 80 to 140mph
VIDEO
After that video we solve the problems and go to the dyno waiting for the boost controller
And it's come this week
Now we can go to the dyno an make some nice videos at WOT.
REgard!!
Hope you like...
The car:
- Rota 17" bronze
- EBC brakes
- EBC redstuff pads
The parts:
- Stock engine
- Skunk2 Cam gear
- Header MSR
- Dowpipe MSR 2.5"
- DSM 450cc
- Oil cath tank MSR
- Dual slim fan
- Greddy E01
Photo:
The fab
Header
Downpipe
Pipping
OIl
Finish
VIDEO
REgard!!
