swapping original motor f22a6
    i through a rod in my f22a6 and im trying to find out if i should rebuild or swap another f22 into it...
    You threw a rod? You NEED a new engine, you can't fix a hole in the block lol.
      Yeaaaahhhhh.... what Tippey said.
      Here's a DIY to remove your engine:
      http://www.cb7tuner.com/vbb/showthre...&threadid=8849
      Just follow it in reverse to install the new engine.
        i know that,i meant just replace the block along with other things or just get a newish one..thanx for the diy link.i needed that.im still new to the honda gam as far as cbs go.
          you can find them motors all day with 100000 or less for like 4 to 500. thats complete. All u do then is do a timing belt an seals and your good.
            for 521.00 on tigerjapanese.com i can get a f22a with less than 35k miles.id love to have a jdm motor but i was trying to find a cheaper option out tho i want the best for my cb....is there another source for my motor thats cheap??
              Unless you're in Canada, don't order from tigerjapanese. They've been known to send bad motors, and it's hard and expensive for international lawsuits.
              http://www.cb7tuner.com/vbb/showthread.php?t=131353
                wats a beter source for one?tiger is all ive ever known of..
                  http://www.jdmenginezone.com/
                  got my H22 from them .
                    i order my motors through my salvage yard. I know the people well so i dont get screwed. They call whoever an have them shipped an i just pick them up. Thats for f22 motors. I never asked about h22 though. The f22 route will be the cheapeast as the h22 swap is 2500 or so. So imo id just fo the f22 route if cost is important to you.
                      is it a salvage yard near southaven,ms?ive checked pull a part and ther all junk,bt yeah my intentions are f series tho in the near future ill need an h...
                        Check Craigslist or JYs in your area. That'll be the cheapest route.
                        If you don't have any luck, contact H-Motors. If they don't ave one in stock, they'll get you one.
                          i checked their motor mall and i couldnt find any f series motors at all...
                            Read the last eleven words of my last post.
                            Just substitute "ave" with "have".
                              do i have to call?
