Which mount is causing the shake?
    Hi guys,
    My car 1990 LX 4AT.
    The front of the car shakes a bit more now days. It shakes the most when in reverse at idle and when the car is at a dead stop. Shakes but much less in neutral. No shake at all when in "D4" shift.
    Which motor mount is bad here? Or are all 4 bad?
    Thanks.
    Probably the front or the rear. Just take a look at all of them and see if any of them are ripped or cracked.
      The front is just a torque mount. Not load-bearing.
      Look at your mounts. If the rubber is broken, then that's your culprit. After 20 years, I'd say they're all bad by now!
        The mechanic wants $330 just for the rear one. Probably one of those cheap after market ones.
          The auto rear mount is a powered, fluid-filled unit. Many people just convert to the cheaper manual rear mount.
            I want to change them out myself but afraid the rear is much more involve than I am capable of.
            Any DIY around?
            Thanks.
              Did you bother crawling under the car to look at the mounts?
              They're motor mounts. You don't need a DIY. The rear is just a pain in the nuts to get to.
