you can see it here right in front of the tire, same on the driver side with the exception of the windshield washer container. you dont have those? they are held on by clips i think. this task just became harder with all these fine details.
Toe Adjustment question.
Just my 2cents but i went to beeline school for laser alinment an yes u can backyard u alignment but it will still be off. Thing is is alignments are done with car down on swival plates. This is the only way to get true alignment. The bars they hook up should have extenders they can put on them so it will stick out past the fender well. Also most laser aligners have a calibration so that when they align it takes into factor the crown of the road. As far as crooked sterring wheel fix just set steering wheel straight an get somthing to wedge between the seat and wheel so it cant move an find a way to pull a string from rear tire to front tire and adjust as close as possible. But again car will likley pull and or still wear tires faster. hope this helps. Dont let shop say they gotta pull steering wheel to straighten it after alignment. Thats bs an they charge extra for that.
To the OP, if you are feeling adventurous, see below it's linked to CSpeed Racings website.
http://bit.ly/flWCCL
