Hey Guys, what's new? hope everything is good. anyway so this morning i after my car at my school, and when i came back like 3 hrs later, there was a puddle of power steering fluid under the front on my car, so i open the hood and it was also all over the reservoir and that area. and suggestion? thanks in advance.
Power Steering Leak
what happens is air gets into the low pressure line due to a bad seal somewhere, and the fluid bubbles out the top of the resivoir. its a common problem with the cb7 and especially after really cold weather. keep i topped up or you could burn your pump.
Originally posted by splitsecondcb View Postcheck if it leaking from the power steering line for any puncture or little cut and also check if the power steering line is bolted down tight. check if the cap on the power steering fluid container is on and not loose. also check the container for any crack that might cause the leak.
