Power Steering Leak
    Power Steering Leak
    Hey Guys, what's new? hope everything is good. anyway so this morning i after my car at my school, and when i came back like 3 hrs later, there was a puddle of power steering fluid under the front on my car, so i open the hood and it was also all over the reservoir and that area. and suggestion? thanks in advance.
    check if it leaking from the power steering line for any puncture or little cut and also check if the power steering line is bolted down tight. check if the cap on the power steering fluid container is on and not loose. also check the container for any crack that might cause the leak.
    Mrs. Reddy
    http://www.cb7tuner.com/vbb/showthread.php?t=178119
    MY FOR SALE THREAD CLICK LINK ON TOP
      what happens is air gets into the low pressure line due to a bad seal somewhere, and the fluid bubbles out the top of the resivoir. its a common problem with the cb7 and especially after really cold weather. keep i topped up or you could burn your pump.
      My Cars: 2006 Ford Freestyle - 1990 Accord EX - 2001 Accord EXV6 Coupe - 1967 Impala "Metallicar" (for the wife)
        If you find any leaks or Cracks i would head to the Junk yard or hit up Ebay and get a new pump and Container. i had to do the same with my Wife's CD5. paid 40 bucks for a "new" pump and lines shipped
          Pretty much what split said, check all your lines going to your reservoir and pump, make sure cap on reservoir on down all the way, make sure pump is bolted on tight enough
            So what did you find out?
            Thanks
