transmission question
    hi there just got my 92 accord dx abought a week ago(first car) and my transmission seems weird its automatic but drives like its stickshift. what i mean is that when you pull from a dead stop you have to take off in one the go to two then d3 and d4 is that normal or is there something up with my tranny any help apreciated! thanks in advance...
    That is not normal. Is your D4 light flashing? If so, your transmission computer is telling you that there's a problem. Read the thread at the top of this section ("read this first") to see how to read the error code.
      The D4 light does not flash car runs perfect the way it is with the tranny like that but I feel like something is wrong......thnaks for the tip I will check out the thread hopefully I can figure this out thanks
        Make sure the D4 light actually works... It should not do what it's doing, and there SHOULD be a problem reported by the TCU.
        Check the fluid level.
          if you put it in D4 and just drive, what exactly does the transmission do ex. does it not shift at all, shift harshly, etc.
          ''COUPE''
          ''WAGON''
