im looking for a replacement for my muffler because it has holes and rust on it ? there are alot of aftermarket ones out there that are cheap what diameters measurments am i looking for ? and does anyone know of ones already tried and tested , im not looking for the bbest just a replacement to get it registered thanks
cheap replacement muffler ?
This topic is closed.
Aftermarket or OEM replacement? if oem replacement, check out Rockauto.com, if it's aftermarket-yes you could try ebay. your stock piping diameter is 1-7/8", most inlets on "performance" mufflers are either 2.25" or 2.5", most generally 2.5. If i were you, i'd just go ahead and replace with a stock replacement.
life is good.
Originally posted by stretch JDM View Posttry to score a 06 SI , JY, muffler . the oem one sounds smooth and it looks nice . i have a friend with a cd5 with a SI muffler he got for 40 bucks . stay away from fart cans'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
Originally posted by mjsstanley View Postif you just want a quick simple OEM replacement , autozone .Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
OEM is generally the best to run. (in my opinion) not sure about any emission laws there, or noise concerns, but the loud muffler can be annoying after a while. talking on your cell phone on the high way with the windows up and all you hear is bbaaaaaaaaaaaaaaaaaaaaaaa made me change mine. also from my parts they have outlawed the so call "angry mosquito" mufflers. plus OEM gives you the gas mileage back that a "high flow" muffler would rob. And lets be real, changing from stock OEM muffler to a "pissed off bumble bee" muffler really doesn't give you a drivable, noticeable gain in horsepower. maybe on the dyno its 2-4 hp but won't shave seconds off your time at the drag strip
The past, to present.
