massive vacum leak help!!
    i just removed my manifold to replace my rear motor mount and after installing everything and i start the car it will have a vacum leak all the way to 6500..it doesnt seem like any regular vacum leak so what could cause it?
    did you replace the im gasket?
    COUPE K24
      yeah i did...could it be leaking from there because it seems like theres minor gap between the engine block and manifold
        did you scrap the old gasket off?
        COUPE K24
          I did but there was some that was stuck to it that I didnt take off
            thats the problem then.
            COUPE K24
              Alright well ill take the manifold off later tonight and hopefully that will solve the problem..thanks man
                Just got done re fixing everything...car seema way way better not but there seems to be a vacum leak now and I check all the wires already, any ideas? The car was good before I remove the manifold
                  Almost forgot..my car seems to be leaking water around the thermalsat however u spell it..could this cause the bad idling?
                    do you have an AUTO trans? did you put the vac. line back on the new mount?
                      Yeah I got that too
