92 accord wont start
    Whats up guys well me and my boy just did my swap and everything went good got it started and drove it around. so then i put a kill switch and once again everything went fine car started a couple times. Then i went for a drive and parked the car turned it off and came back in about an hour try turning it on and for some reason it did not want to start. it did not crank or anything. still till this point it don't want to crank. can some one help me.....
    Ok, you have an unknown engine in your car. You and your boy did the work, and we have no idea exactly what it was you did... You installed a kill switch somewhere that cuts off power to... something.
    The car starts sometimes, but not every time. Which means sometimes it is getting spark and fuel, other times it is not getting one or both of those things.
    Figure out which of those things it's not getting, and then figure out WHY it's not getting it. I apologize for the vague answer, but you really didn't give me much to go on here.
      sorry you rite well we did a h22 swap, and its not thats its not getting spark or anything its not turning over at all its like when you don't hit the clutch and try to start it. sorry man i'm kind of new at this, still learning.
        Just give every possble detail you can. We don't have access to your engine, your swap process, or your brain... so we need the information to be able to help you!
        If it's doing nothing at all, then check that clutch switch, check the ignition switch, check your killswitch wiring...
        Does it do anything at all? Like, does it click and then shut down all the dash lights? if so, check your battery connections.
        I'm really just taking shots in the dark here.
          roll it off a mountain
            Please give useful advice. If not, you probably won't last long on here.
