I cant start my H22 swapped CB7 because the plug in for the clutch sensor is missing and I don't have it is there anyway I can bypass it? and there is a metal box that says AT on it what is that for the plug for it is also missing? Need some help...
How do I bypass the clutch sensor for the ignition?
Are you talking about the clutch pedal sensor under the dash? If so just connect the two sides with a jumper wire.My Member's Ride Thread
how did you start the car before the swap?
edit: the only "box" I can think of with an AT on it is for the cruise control. If that's the case, you might try reading this:
http://www.cb7tuner.com/vbb/showthre...085#post703946Last edited by 90accords; 02-13-2011, 04:54 AM.
did you do a 5spd swap from Auto? AT usually means Automatic, and MT is Manual.
But I didn't have that issue when going from Auto to 5spd. Never had to wire in the Neutral Safety Switch, although I kinda want to now to make my cruise control work.
naw always slandered, and I think it is a cruise control unit. I had a harness from my old 1992 cb7 H swap that got totaled and I kept the harness and took out the stock one out of my new 1990 and put the 92's H one in. now I notice to late that there are a ton of open plugs and my power windows and seatbelts don't work and car wont start:/ I didnt think the project through and now have plenty of problems... oh well, I am just going to go to a pull part yard and get all the pieces of the harness I am missing.
