My Window Problem
    My Window Problem
    my 1991 honda accord se has not prob except the driver side window is screwed up. when it goes down, it goes like 1-3 inches down then it gets stuck
    and when its going down or up its making a really loud grinding sound, im not sure what it is but i took off the door panel and i couldn't find what it was.
    i Hope you know thx
    i Hope you know thx
    it sounds like either your regulator assembly is screwed up or simply the motor itself is
    Originally posted by scudweiser
    it will go vrooooooom bauggggghhhh mmmmmmaauuugggg. Still no mmmmmbAAAAAAAUUUHHHHHHH though.
    Do you have anything intelligent to offer, or are you just trying to whore up your post count?
      with the door panel off, lean it up against the door and plug in the power window plug ( the biggest plug in the door panel ). Run your window up and down and look\listen for where it is making all the noise. There is only so much to the window, should be easy to track down. Might just need some grease, might be something stuck in one of the tracks, could be a bolt that came loose and threw everything off. GL
      Bought from Darkcloud
      http://wheelflip.com/r/DrAkE
