its idleing around 500rpms and when i accelerate from a stop it kinda feels like the ebrake is up or something would the low idle cause that or should i check my ebrake lines? thanks f22b is the engine ttried askin in cd5 tuner but they r no help
low idle...slow acceleration
Follow the procedure to properly set your base idle. Make sure your IACV and FITV are functioning properly. Definitely check your ebrake lines to make sure they aren't stuck... that does happen (hell, it happened to me in my 09 Fit!)
Is your CEL on?
It may not matter, but which F22B? F22B with no number is the JDM DOHC Prelude Si engine. F22B1 and F22B2 are the 5th gen engines.
ALWAYS be specific about your engine when asking for help... which engine you have could make a BIG difference in diagnosing the problem. Especially if it's a swap!
