So for the past few months I had been suffering from this random engine bogging and backfiring under acceleration. It seems its not uncommon on this forum, although I fixed the problem by replacing my IAC assembly, not replacing the usual things. Which is why I'm curious about it.
I found that a vacuum line on the solenoid (that comes from the chamber it's mounted to) had broken off. So I went to the junkyard and got a new one for $25. I put it in and it seems to have fixed the problem. But after some more research into the matter it appears that piece is not exactly necessary when an aftermarket intake is installed.
Which brings me to the situation: I went and unplugged the solenoid yesterday and the engine began to act up once again. So I pulled the vacuum line that connects it to the manifold(?) and capped it. But that actually made it worse! So I hooked it all back up and everything is fine again.
But the mystery still remains for me as to why a "noise suppressor" for a stock intake is causing my motor to run rough even though I have a short ram. I'm open to any thoughts on the matter. Though I've already ruled out the possibility of a mouse living in my motor just F"ing with me for fun.
