how does the diameter of a throttle body effect performance?
throttle bodys
oo speaking of throttle bodies....does any one know if the F22 and H22 plenum are the same?..reason i ask is because if i got a throttle body for my current f22 would i be able to use it on my H22 when i drop it in?
im trying to make the best of my F22 at the mo because the H22 aint for about another year
No, they are not the same. The F22A6 plenum will bolt to the H22A runners... but you'd be swapping on a smaller plenum. Not worth the tradeoff for a modified throttle body.
If you're putting the H22 in, don't waste money on the F22. If the H22 is a year away, save for a year... and do some SERIOUS upgrades with that money you saved. Don't piss it away on an engine that you're going to yank out.
lol yeah bigger diameter is better.
the more air you can flow into the engine the more power it will create.
BUT you might need to look into what else would go good with the larger throttle body. if your gona do one thing you may aswell look at doing it all...money willing. its just to ensure your getting the best out of it is ill
Just remmeber that the engine is a giant air pump. In order to make power, it has to be able to breathe... in and out. You'll only make as much power as your biggest bottleneck allows. A big throttle body will allow more air to come in, but if the engine can't get that air out, you're not going to see any benefit. If anything, you might actually lose power.
Don't start slapping parts on your car without knowing what they do, and how they interact with the other parts installed.
There is no point in increasing the throttle body size if it does not match the diameter of the intake manifold. Besides, if your motor does not have the capability to flow more air (from a larger cam, longer stroke, bigger bore, forced induction, ect..) then increasing the throttle body diameter on a stock motor will most likely hurt performance. A larger diameter will decrease the velocity/momentum of the air being drawn into the plenum.
Originally posted by 98vtec View Postit wont hurt performance, just wont help.2013 Ice Cream Cruise!
VIDEO: 2012 Ice Cream Cruise
VIDEO: 2012 Ice Cream Cruise part 2
The single largest cruise in the Midwest!
August 3 ~ Omaha, NE
By 1320 Video
Member's Ride Thread
