Basically I want to build my F22A1 while keeping it naturally aspirated and I would like to hear some opinions on my ideas. I already have a short ram intake, Apexi cat-back exhaust system, a Magnaflow cat, and a Megan header and downpipe. In the near future I plan on doing an engine rebuild. In the not so near future my plan is to get a reground Bisimoto camshaft, Bisimoto valvetrain, Bisimoto intake manifold, Bisimoto pistons, and Golden Eagle throttle body. I would also consider going with a Bisimoto header from my Megan header. This will all not be for a while since I'm still in school and not the most financially stable. I just want to see your opinions on this build.
F22A N/A Build
Originally posted by capo_status View PostBasically I want to build my F22A1 while keeping it naturally aspirated and I would like to hear some opinions on my ideas. I already have a short ram intake, Apexi cat-back exhaust system, a Magnaflow cat, and a Megan header and downpipe. In the near future I plan on doing an engine rebuild. In the not so near future my plan is to get a reground Bisimoto camshaft, Bisimoto valvetrain, Bisimoto intake manifold, Bisimoto pistons, and Golden Eagle throttle body. I would also consider going with a Bisimoto header from my Megan header. This will all not be for a while since I'm still in school and not the most financially stable. I just want to see your opinions on this build.
good luck though!cb7 rebuild coming soon!
its expensive to build ANY na motor. the f22 is no more or less expensive. if you want cheap power, get a v8.
dont forget that you will need new rods as well. plus bearings, all seals, and if you want to make proper use of everything you will want a tunable ecu, tuned on a dyno by someone that knows what they are doing.
take your time. do your research. plan out your build before buying even one more part. dont waste money buying things that wont help you achieve your original goal. dont give into gimicks. just get what you need. stay focused. if you need a good example to follow take a look at hondafan's white build.
Originally posted by Chase d cb7 View PostI would add the A6 parts to your list atleast, but what makes you want a n/a f22? just curious.
.peace.
As said above... just stay focused. Don't go cheap, and don't deviate from your plan. Once you start wasting money on parts that don't help you toward your goal, you'll find yourself in a neverending process... and the results won't be very satisfying.
I would recommend porting at least the exhaust side of the head if you are going to the level with all the other headwork. The Megan header is going to be a huge bottleneck, as will your entire exhaust system most likely.
It will be expensive, you have to know that going in from day 1. Before you start buying parts you should have your entire build planned out, otherwise you will fall in the trap that deev mentions about buy stuff over and over.
http://www.cb7tuner.com/vbb/forumdisplay.php?f=61
There are plenty of F22A N/A builds in the NA section. I'd suggest finding a setup that is putting out numbers that you are interested in achieving, see what work they've done, and base your build on their findings.
Well he's not spending money on a swap which he could do cheaper and easily, just to gain the experience. OP, this is great, they're as fun to build as any singlecam. But here's an idea, why not buy a rebuilt A6 head, port and open up flowchart a bit, H23 IM and plenum or the like, the bisi heat insulating gasket, and a bisi header. That would give you nice results, and you wouldn't have to dig deep in the bottom end if you don't wanna. Dan (GraniteCB7) is the only guy I know personally who has one around here and he just loves it. Whatever you do, like the guys said and I can't stress enough; don't go cheap take your time and learn what you haven't yet, and most importantly have fun.
life is good.
Thanks for the input everyone. I've actually been taking a look at many different F22a N/A builds to see exactly what I wanna do. This is still in the planning stage, and I do have a lot of time to plan for it, since I'm still in school. It is possible that I might decide I'd rather go turbo, but I'll have a definite decision before I start anything. I'm just looking for ideas and opinions right now. The reason I want to build this engine rather than doing a swap is because I figure this will be more fun and will feel more rewarding in the end.
Bisi's ITBs are a solid $2200, and I feel ITBs in general are a little overkill for this build.Last edited by capo_status; 02-02-2011, 09:49 PM.
