F20b strange hybrid idea
    Alright, I've read through the swap FAQ's, the swap guides, multiple threads, and posted something along the line of this, and I was told by deevergote that the f20b head will fit on an h22 block. So what I want to know THIS time around is....
    Is it possible (and practical) to bolt the f20b head onto the h23a1 block?
    Any responses are appreciated.
    H23A1 bottom end is apparently fairly weak. I wouldn't.
    F20B manual swap is a pretty good package, and fairly inexpensive as well. Why not swap it in as is?
    1992 Accord Wagon (RETIRED)
      Weak in what aspect?......
      And I only have the F20b head. I scored it for 160 bucks, I figured I'd tinker with it until a cheap H22 block/F20b block dropped on me.
        Originally posted by Gr1m View Post
        Quote from The G-man "What I don't see the point in is slapping a DOHC VTEC head on a block that can't rev high enough. You will never make 175-200 hp to the crank by just slapping on a head."
        Found the answer, i guess.
          It could be done, but it might end up being less reliable and more costly than you'd hope. It sounds like money is tight, so messing around with stuff (unless it all falls into your lap) is probably not in your best interest. If you have money to spend, and the ability to have your car be immobile while you're figuring things out, then go for it. Hybrid engines are fun, and a great learning experience... but if you're a beginner, they are almost guaranteed not to be reliable OR cheap.
