well my project 1990 honda accord ex with f20a sohc automatic had just been finish about two weeks ago. When i first had the car up and running there was no transmission fluid so i fill it up to the marker on the tranny dip stick. Now two weeks later of driving my project car around town and some highway driving the dipstick on the tranny show no fluid at all. the reason why i checked it again was because the car didn't want to pull when i step on gas thats when i check the fluid and dipstick was empty. this is my second time refilling the tranny in one month. i checked the bolt to drain the tranny its tighten and no fluid is leaking out from there. I look all around the tranny and i see no fluid is leaking out. what could be the problem? could the transmission fluid be leaking to the bottom block? and my car still showing code 1 and 2. Is my tranny going out? I am ready to get another used 90 cb7 because this car have alot of issue or else i am going to buy a used stock automatic prelude lsd and see if it would fix the changes. i don't want to just spend money i do like to resolve this problems but it have alot of mixing stuff.
Transmission Fluid Running Low
Do park over a clean piece of cardboard, but also think of all the places it could go.
I know that coolant lines run into the trans, check your coolant.
I don't know if it's possible, but I guess it could run out and leak into your block. I'd think you'd be seeing other issues though.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
okay I am going to rinse the transmission and see if there's any leak when i get out from work. and also now since i refill the tranny fluid on the way to work today. the car kept on dieing out on me. i try to drive over 3k the rpm gauges start going crazy and the engine bog. if i was to do a complete stop the car die out..
Is your check engine light on?
You may have something binding in the transmission if it's not engine-related. When my throwout bearing seized, that happened to me. I had to drive without the clutch for 150 miles, and give it gas any time I came to a stop to keep it from cutting out. FRIED the clutch and everything associated with it, too!
I assume you're automatic (didn't scroll back up to see if you said so....) If that's the case, and somethig is bad, you might be better off just shopping for another transmission. Some serious damage could have been done already.
Originally posted by deevergote View PostPull the code for that CEL and see what the problem is. Fix what you can. Keep fluid in the transmission.
Originally posted by splitsecondcb View Posthow do you pull code for the CEL? is it when i jump the blue plug under the passenger side? if it is. my sis light get one fast blink and two fast blink. here whats else occur yesterday, i got home from work i park in the drive way. i clean out my tranny and was planning to park the car in the garage and put card board under it. i started the car and it started up normal. but once i put in drive and press on the gas the car shut off. i did it the second time. start up the car and once i press on gas a little bit the rpm go down and when i press harder it go down all the way to the point the car shut off. i think there is alot of problem with this car. this one is really confusing me.
The CEL will blink to give you your engine problems. The D4 light will blink to give you your transmission problems.MRT
Originally posted by GeoffMisiak View PostCan you be more specific with your codes?
I'm not sure how the 9091s work. I thought it would be similar to the 9293.
Best guess is the S is for the trans and the CEL is for the Engine. If the CEL isn't blinking, then you have no codes for the engine. If the S light blinks, then you have codes for the trans.MRT
Originally posted by GeoffMisiak View PostI'm not sure how the 9091s work. I thought it would be similar to the 9293.
